Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard it
Compression:
If both correct fuel pressure and snapping blue spark is present-check engine compression could be a valve and ignition timing, issue -this will lead you to problems with compression and valves opening and closing at the wrong time/broken or jumped timing belt/chain
SPONSORED LINKS
Wednesday, February 10th, 2010 AT 2:15 PM
