I have a problem the truck will start and run for about 10 min then die, I will try to start it and it will only crank when I check for fire at the plug wires there is none, but after I let it sit and cool down it will start again, Its like somthing is getting hot like the coil any info would be appreciated.
SPONSORED LINKS
Friday, February 12th, 2010 AT 9:47 AM
