2002 Chevy Trailblazer
CHAVEZ75
  • 2002 CHEVROLET TRAILBLAZER
2002 Chevy Trailblazer 6 cyl Two Wheel Drive Automatic
trailblazer will not start. Checked the spark and that was good, checked the fuel pressure and that was good. Help
Wednesday, January 6th, 2010 AT 5:24 PM
What is the fuel pressure reading? And are the injectors pulsing?
Wednesday, January 6th, 2010 AT 6:22 PM
CHAVEZ75
Fuel pressure is at 48 osi but after 5 seconds it drops down to 44 or 45 psi and the injectors I did not check that
Wednesday, January 6th, 2010 AT 9:07 PM
Okay with the fuel pressure -now crank engine over and listen to the injectors if its clicking/pulsing or use a noid lite
Wednesday, January 6th, 2010 AT 11:32 PM
CHAVEZ75
Got the trailblazer running, but it is running rough. I checked each coil by disconnecting the electrical connection of each one and I got a difference of idle drop on each one but the # 3 coil had no change in idle, and then two trouble codes : p0340 and p1515 did those codes come on from checking each coil the way I did or is it something else
Sunday, January 10th, 2010 AT 9:17 AM
Misfire at a specific cylinder-check sparkplug, compression and injector for no.3
Sunday, January 10th, 2010 AT 3:29 PM
