2002 Chevy Silverado
WADEHUDSON
  • 2002 CHEVROLET SILVERADO
THE TOW/HAULING WON'T RELASE. PICK UP STAYS IN TOWING
Tuesday, December 15th, 2009 AT 5:08 AM
  • 109,758 POSTS
Chances are the switch on the shifter is bad or has become shorted. You need to remove it to check which requires disassembly of the steering column to access the wires from the switch. Once there, check for continunity between on and off at the switch. If it doesn't change, replace the switch.
Friday, December 18th, 2009 AT 10:35 AM
