1993 Chevy Lumina 3.1L V-6 won't start
REVKEV316
  • 1993 CHEVROLET LUMINA
  • 6 CYL
  • 160,000 MILES
Our garage ministry has a 93 Chevy Lumina 3.1L Fuel Injected v-6 we are working on. The engine will crank but will not start. It has spark and the fuel pump cycles when first on and after every crank. Tried a shot of starting fluid in the intake hose but nothing happened. What next?
Wednesday, February 25th, 2009 AT 3:27 PM
Try disconnecting the air intake hose from the throttle body spray in there it should fire up if your getting spark.
Thursday, February 26th, 2009 AT 12:28 AM
REVKEV316
  • 18 POSTS
Okay, just tried spraying inthe throttle body but still nothing. I also checked the spark on two of the plugs and both fire well. ? How do I best check the fuel supply?
Thursday, February 26th, 2009 AT 2:47 PM
Hook up a fuel pressure tester to the fuel pressure test port on the fuel rail
If you've sprayed the fluid in the TB and have spark it should combustion and immediately stall-
Verify the valve and ignition timing before the fuel system-something is wrong here
Thursday, February 26th, 2009 AT 2:53 PM
