Yes, you must check those things, I do believe its starving for air, you can start by checking the air filter, and accordion hose, easiest stuff
Hi chad, I don't believe this is anything "major" , but it will take a little detective work. I didn,t understand what you said about the pressure regulator, but when this no start condition happens it is necessary that we check the fuel pressure and for spark , I will show you some easy ways in my next post. but. I am thinking maybe crank sensor, cam sensor possibly fuel pump relay or regulator, but we need to do these checks and get back to me with you findings please
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Thursday, April 15th, 2010 AT 6:16 AM
