2000 Chevy Cavalier
CORONER27
  • 2000 CHEVROLET CAVALIER
Heater problem
2000 Chevy Cavalier Front Wheel Drive
Our engine has been overheating and the heat isn't as hot as it usually is. It blows cold air out for a while even when engine temp is at the half way mark. What could this be? Some people said heating coil but how can I know for sure without taking it to a mechanic?
Tuesday, September 21st, 2010 AT 2:32 PM
  • 109,758 POSTS
If the engine is overheating, make sure the coolant is full. If it is, you may have to replace the thermostat. If that doesn't work, then my next suggestion would be to check the head gasket.
As far as the heater core, start the engine, let it warm up to normal operating temp with the heater on high, and feel both heater core hoses (supply and return). Both should be hot. If they are, the heater core isn't plugged. Please keep in mind, a bad head gasket can cause air pressure to get into the cooling system. Many times that will cause an air pocket that will prevent the heater from working and the engine to over heat.
I would start simple, the thermostat.
Thursday, September 23rd, 2010 AT 9:12 PM
