98 Blazer - runs rough and loses power
MISCHIEF12NH
  • 1998 CHEVROLET BLAZER
Hi.I have a 98 Chevy S10 blazer with 175K on the 4.3L 4 x 4 engine. I stared out a couple of months ago with my blazer hesitating when I stepped on the gas, then it proceeded to start backfiring & finally it would not go anywhere when the accelerator was pressed. Was throwing a multiple cylinger misfire code when tested. I replaced the distributor cap & rotor, spark plugs & wires, EGR valve, etc and no luck. Towed it to the mechanic and he said it was the fuel injection system & possibly the Cat converter. Replaced both along with the fuel filter (both looked horribly clogged) and it runs better, but still not enough for me to drive it on a regular basis. Still has trouble getting out of it's own way when you press on the gas (especially uphill) and the check engine light is back on & flashing. Also continues to backfire intermittently. Engine sounds good (no knocks but runs better when cold than when it warms up. Any ideas? Please help.I just want to be able to drive my truck again.=) Thanks so much!
Saturday, October 6th, 2007 AT 4:13 PM
2CARPRO JACK
  • 11,533 POSTS
Is th echeck engine light still on?/ Have it scanned for the trouble codes. Could be a weak fuel pump if it has never been replaced, have your tech do a pressure test on it. Get back to me with the codes, Autozone will scan it for free
Sunday, October 7th, 2007 AT 8:12 AM
