1995 Chevy Blazer relay problen
CCNEELEY
  • 1995 CHEVROLET BLAZER
1995 Chevy Blazer 6 cyl Two Wheel Drive 125000 miles
i put new relays in and it worked at first but it kept burning the up but now it will die while im driving and have to wiggle the relays in dash to get it to start
Thursday, February 11th, 2010 AT 5:46 AM
JDL
  • 16,098 POSTS
Hi, are you talking about the fuel pump relay? Maybe a faulty wiring circuit? How long since a tune-up? A dirty fuel filter might cause the pump to work harder than it should. Use a gage and check fuel pressure. Also, there is an oil pressure switch in parallel to the relay. Once you crank it enough to bring up oil pressure and the switch closes, the pump should run, even without the relay.
Thursday, February 11th, 2010 AT 6:55 AM
