1996 Chevy Astro Astro van won't start
REVKEVACTS238
  • 1996 CHEVROLET ASTRO
  • 6 CYL
  • 168,000 MILES
My Astro van recently started having problems with power when going down the highway. When I wanted to pass it would bog down, I added some fuel additive and it helped, then it refused to start. I replaced the fuel filter and it helped for about a month.
Then it began to have to have fuel additive added before it would start. Now it takes me turning the ignition on and off for about ten minutes to get it to start. Once the vehicle has been sitting a few hours it begins this all over again.
Replaced fuel filter again but still help. I can hear the fule pump initiate, but it sounds different to me.
Could this be the fuel pump or the injectors, or spark plugs fouling out? And how would I find out which one is the culprit?
Friday, April 30th, 2010 AT 12:24 PM
INTERNETMECHANIC
  • 700 POSTS
If you think it is a fuel problem, use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage, you can call and ask? Fuel pressure spec for 4.3L, 60--66 psi.
Friday, April 30th, 2010 AT 12:30 PM
