1994 Buick Lesabre won't start!
RUKIS
  • 1994 BUICK LESABRE
Engine Performance problem
1994 Buick Lesabre
After I run my lesabre for a while & then turn it off, it won't start again unless I spray starting fluid into the throttle body. Why does it do this!
*is it a fuel injection problem?
i've already replaced my spark plugs, wires & mass airflow sensor. Car has had complete tune up & fuel pressure has been checked & ok'd. I just don't understand.
Tuesday, July 15th, 2008 AT 8:38 PM
TUCSONDIRECT
Even tho you have tested the pressure check your fuel filter, (last resort) when you turn the key turn it tothe run position and let it sit about ten seconds, then crank the engine this works with mine everytime? Notsure why it does it but. All systems checked out fine and I couldnt figure it out the only thing that I can think of is that it might be an issue with the fuel dist. System and when it sits there is air in the line from low fuel? Hope this helps atleast a little
Monday, January 6th, 2020 AT 3:40 PM
