1994 Buick Century
JOLVERA1
  • 1994 BUICK CENTURY
  • 6 CYL
  • FWD
  • 170,280 MILES
Overheated and wont start
Tuesday, September 15th, 2009 AT 4:32 PM
If the engine is turning over and will not start do below and comeback with some results
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Tuesday, September 15th, 2009 AT 6:41 PM
