Disable the alarm system
ARGIRO TZIAKAS
  • 1991 ACURA LEGEND
  • 3.5L
  • V6
  • 190,000 MILES
My alarm went off and I cannot get my car to start.
Wednesday, February 15th, 2017 AT 9:12 AM
STEVE W.
  • 13,544 POSTS
Insert the key in the drivers door lock. Turn the key left, then immediately turn it all the way to the right. That should reset the factory alarm, unless there is a problem with the door lock switch.
Wednesday, February 15th, 2017 AT 9:19 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,198 POSTS
This guide should help as well
https://www.2carpros.com/articles/how-to-reset-a-security-system
Tuesday, March 19th, 2019 AT 10:56 AM
POSSIA
  • 1991 ACURA LEGEND
1991 Acura Legend 6 cyl Front Wheel Drive Automatic
My car alarm activates when I lock the door. Why when I unlock the door, the alarm sounds and will not cut off?
Tuesday, March 19th, 2019 AT 10:57 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi Possia,
Did you use the remote to unlock the doors?
POSSIA
No I do not have one. I used the key to unlock the door.
KHLOW2008
  • 41,814 POSTS
Hi Possia,
ALARM NOT CANCELED WHEN KEY IS INSERTED IN IGNITION SWITCH
1. Check for a blown fuse No. 20 (7.5-amp) in the under-hood fuse block.
2. Check the ignition switch.
3. Check security control module input.
4. Check for open circuit, loose or disconnected terminals on control module Black/Red and Blue/White wires.
Page 1 of 1 ANTI-THEFT SYSTEM -1991 Acura Legend 9/10/2008
CSCHMITZ
  • 1992 ACURA LEGEND
  • 6 CYL
  • FWD
  • 50,000 MILES
Hi, can you pleas tell me, how to deactivate the alarm system?
When I pull the fuse of the horn, it is deactivated, but the horn also.
I don´t need the system.
I wished I could take the module completly out. Where is it lokated?
Thank you very much for any tips.
Yours, Christian
KHLOW2008
  • 41,814 POSTS
Hi Christian,
Try unplugging the module under dash on driver's side.
https://www.2carpros.com/forum/automotive_pictures/192750_AlarmControl92Legend_1.jpg
AZCRUISER
  • 1993 ACURA LEGEND
  • 6 CYL
  • FWD
  • 175,000 MILES
The car alarm started comming on and the car would stop running. But would start again with the key. Now the car has stopped and the key will not start it won't turn over radio doesn't work windows don't work just the head lights dome light and turn signals?Believe the car had a second alarm installed that worked off a panic switch that would turn the car off if a buton was pushed but the button have kind of crumbled in the desert heat hear AZ. Do you think if I were to hook the wires in the button thingey together that it could help or am I stuck getting it towed to a dealer its a 16yr old car but still a pretty nice ride and fast and smooth riding if it were runnning. My othe car is a 1977 toyota land cruiser that has 300,000+++ mile and keeps going and going
KHLOW2008
  • 41,814 POSTS
Hi azcruiser,
Cause of problem should be power supply interruption and possible causes are :
1. Faulty ignition switch.
2. Loose main fuse and or connections.
3. Faulty alarm controls. Check if the fob button is self applying due to a bad internal spring. Try removing the fob battery and not using it to test if problem occurs
