1991 Acura Integra turnover but willnot start
BRUCE1340
  • 1991 ACURA INTEGRA
  • 4 CYL
  • FWD
  • MANUAL
  • 130,000 MILES
I tried replacing the coil but it didnot help
Saturday, October 10th, 2009 AT 2:08 PM
Do below to determine if its fuel or spark problem
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Saturday, October 10th, 2009 AT 4:09 PM
