HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Expedition
Engine
Symptoms
Not Cranking Over
No crank no start issue
FREDDY121404
MEMBER
2020 FORD EXPEDITION
3.6L
6 CYL
2WD
AUTOMATIC
30,000 MILES
Vehicle won’t start, does not crank, dash lights turn on. It does not lock. Shows full accessory power active message.
Sunday, April 10th, 2022 AT 10:58 AM
WENDY W
MECHANIC
Was the vehicle running poorly before this? Have you been able to retrieve any error codes?
These guides will help you run some quick system checks:
https://youtu.be/dCjmRL3p4Cs
Please let us know what you find and we'll be happy to help further.
Thanks, Wendy W.
SPONSORED LINKS
Monday, April 11th, 2022 AT 7:50 AM
Please
login
or
register
to post a reply.
Related Engine Not Cranking Over Content
My Engine Will Not Crank Over?
V8 Two Wheel Drive Automatic 85,000 Miles. My Suv Will Not Crank. My Observations So Far: 1. On The "message Center", Where The...
Asked by
jimwhitingtx
15 IMAGES
2003
FORD EXPEDITION
GUIDE
Not Cranking Over
When your engine is not cranking (turning) over it will be mainly due to three separate areas, first it could be the battery, cables or poor connection, next is the starter...
Why Is The Starter Not Working?
Have Changed Starter Checked Battery And Alternator Still Does Not Want To Turn Over. It Runs For A Couple Days Then Will Not Start. Lights...
Asked by
wpaxton
1 IMAGE
2003
FORD EXPEDITION
It Wont Crank, No Sound Or Nothing. Check Starter, Starter Relay, Solenoid And Ignition Switch. I Tried To Jump The Solenoid, Nothing.
Asked by
kddavis1
1998
FORD EXPEDITION
Sounds Like Starter Turning Over When Car Is Already...
I Am So Frustrated. I Have No Idea What Is Going On. The Car Is Fine When In Drive, But In Any Other Gear, It Sounds Like The Car Is...
Asked by
keico27
1998
FORD EXPEDITION
Starter Problems
My Suv Has Recently Refused To Crank The Starter Motor When The Engine Is Hot. When Allowed To Fully Cool The Motor Will Crank And The...
Asked by
DetyredNow
1998
FORD EXPEDITION
VIEW MORE
SPONSORED LINKS
Battery Replacement Guide
Starter Motor Replacement
How to Test a Car Battery
Online car repair manuals
