The overflow tank is full but when I attempt to add antifreeze to the radiator it runs straight out on the ground.
Tuesday, December 13th, 2022 AT 2:26 PM
MECHANIC
Either we have a failed radiator hose or the radiator itself has a hole in it. Are you able to see approximately where the leak is coming from? Could you take a few pics so I can see where it could be leaking from?
Check to make sure it isn't the lower radiator hose. Also, here is a link you may find helpful:
