Intermittent starting issue?
NFLENT
  • 1996 OLDSMOBILE CIERA
  • V6
  • 60,000 MILES
It starts sometimes, but not every time, and it seems to have a direct correlation with the brake pedal and at what pressure, it is very odd. I've changed the starter, No change. My next step is the Ignition switch. Just not trying to spend money I don't need to on parts. Any advice would be appreciated.
Wednesday, September 6th, 2023 AT 4:08 PM
  • 108,524 POSTS
When it doesn't start, does the starter engage or does nothing happen? Also, please explain the brake pedal's correlation to the no-start.
Additionally, let me know if the check engine light stays on when the engine is running, if the vehicle runs normally in most cases, and what needs to be done to make it start when you have a problem.
Wednesday, September 6th, 2023 AT 6:02 PM
Related Engine Not Running Content
