When doing engine swap does mechanic change transmission fluid
IRENE1988
MEMBER
2009 MITSUBISHI GALANT
2.4L
4 CYL
2WD
AUTOMATIC
69,000 MILES
I recently swapped my engine does a mechanics change transmission fluid when doing a engine swap?
Wednesday, October 28th, 2015 AT 5:47 PM
CARADIODOC
MECHANIC
Nope. The engine has nothing to do with the transmission fluid. It IS customary but not required to change the oil after starting the engine if the history of that oil isn't known.
