If some wheel lug nuts are torqued and two are gun tight what will happen?
YOMESSSI
MEMBER
2018 LAND ROVER DISCOVERY 3
13,009 MILES
If some wheel lug nuts are torqued and 2 are gun tight what will happen?
Monday, October 23rd, 2023 AT 11:15 AM
KEN L
MASTER CERTIFIED MECHANIC
If the wheel lug nuts are not tightened correctly it can cause the brake rotor or rim to warp and cause a vibration in the steering wheel, also it can cause one or more of the lug nuts to come off while driving or the wheel stud can break. Are you having a problem?
