Water in oil, loss of pressure
JEFFK.
  • 1986 TOYOTA PICKUP
  • 2.4L
  • 4 CYL
  • MANUAL
  • 130,000 MILES
Oil light came on, had loss of power. Thought possible oil pump. Drained oil found water in oil. Can water get in oil besides head gasket, or cracked block?
Saturday, February 27th, 2016 AT 1:28 PM
WRENCHTECH
  • 20,758 POSTS
Yes, it the engine has an oil cooler it can get in that way, Some engines have coolant going through the intake manifold and can let it in that way. Other than that, cracked head or cracked block are the most common.
If the oil has a red tinge like trans fluid, it could be a bad radiator.
Saturday, February 27th, 2016 AT 1:38 PM
THIS IS MIKE
  • 686 POSTS
JEFFK.
Saturday, February 27, 2016 10:33 PM
Also, car did not over heat. If not warped, could I put new gasket without machining?
Monday, February 29th, 2016 AT 9:49 AM
WRENCHTECH
  • 20,758 POSTS
Never. You have to send it out to be both pressure tested and surface machined.
Monday, February 29th, 2016 AT 9:56 AM
THIS IS MIKE
  • 686 POSTS
JEFF K.
Thank you :)
Friday, March 25th, 2016 AT 8:42 PM
