HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Volkswagen
Passat
Engine Cooling
Coolant Temperature Sensor
SPONSORED LINKS
2004 Volkswagen Passat Engine Coolant Temp Sensor
K NIGGEMYER
MEMBER
2004 VOLKSWAGEN PASSAT
Engine Cooling problem
2004 Volkswagen Passat Four Wheel Drive Automatic 45,000 miles
V6 2004 Passat. Where is the engine coolant temp sensor? Pics/diagrams and directions available? Thanks
Friday, September 18th, 2009 AT 9:20 AM
BLUELIGHTNIN6
MECHANIC
For the 4.0L engines, it is located near the top right of the radiator. On the radiator cooling pipe.
For the 2.8L engines, it is located on the rear of the right cylinder head.
SPONSORED LINKS
Friday, September 18th, 2009 AT 11:05 AM
Please
login
or
register
to post a reply.
Related Coolant Temperature Sensor Content
1999 Volkswagen Passat Engine Coolant Sensor Pops Out
Sir: I Have A 1999 Passat In Which The Engine Coolant Sensor "pops Out". It Has Done This 3 Times In The Last Week Despite Changing...
Asked by
AustinMaxwell
1999
VOLKSWAGEN PASSAT
VIDEO
Coolant Temperature Sender Replacement
Instructional repair video
GUIDE
An engine coolant temperature sensor also described as an ECTS (electronic coolant temperature sensor) is designed to tell the car's computer how hot the engine is running....
2002 Volkswagen Passat Coolant Temperature Sensor...
I Need To Change The Ect Sensor On My 02 Passat Se Tdi, But Am Having Problems Locating It. Does Anybody Have A Detailed Description Of...
Asked by
1964johnr
2002
VOLKSWAGEN PASSAT
1999 Volswagon Passat
I Have A 1999 Volkswagon Passat 1.8 Liter Turbo. When Below 50 Degrees Car Would Start Once Then Die And When U Tried To Start It Again It...
Asked by
centercityauto
1999
VOLKSWAGEN PASSAT
2004 Volkswagen Passat Coolant Flange Replacement
On My Car, There Is A Coolant Flange That Mounts To The Back Of The Cylinder Head That Is Leaking. It Is The Housing For The Coolant Temp...
Asked by
raptor75104
1 ANSWER
2004
VOLKSWAGEN PASSAT
Oil In Coolant
2001 Passat. Check Engine Light Came On. Autozone's Free Check Found An O2 Sensor Went Bad. Upon Having That Fixed, My Mechanic-friend...
Asked by
bobbywyatt86
1 ANSWER
2001
VOLKSWAGEN PASSAT
VIEW MORE
SPONSORED LINKS
Coolant Temperature Sensor Replacement
How to Read Codes
Online car repair manuals
