Air bag operation
AIR1MJO
  • VOLKSWAGEN
Have a 2004 volkswagon new beetle, 34,000 miles engine is a TDI was involved in a accident. Ran off the road in to a ditch. Went from 50MPH to 0 in about 50 feet. Hit the left front vendor drivers door and left front tire. Most of the impact was to the left front wheel. (Broke the link between the sway bar and steering arm) question is should the airbags side or front have deployed? Do you have to trigger a sensor such as a pressure sensor or is it an accel. Such as a MEMS?
thanks
Friday, March 16th, 2007 AT 12:31 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,570 POSTS
Yes there are senors that deploy the air bag system, it is not uncommon for the air bags not to work, scan the conntroller and check for codes, you may have a weak impact sensor.
Wednesday, March 21st, 2007 AT 10:30 AM
