2004 Volkswagen Jetta coolant temperature sensor
MURPHY1290
  • 2004 VOLKSWAGEN JETTA
  • 4 CYL
  • MANUAL
  • 25,000 MILES
Please help me locate the temperature sensor. I was told that the problem code was for the sensor and suggested I replace it. I bought one and now I need to know where to find the spot.
Sunday, December 7th, 2008 AT 10:38 AM
JAMES W.
  • 2,394 POSTS
What size engine do you have? There are 4 different loactions. Most are on the driver's side forward in the area where the radiator hose connects.
Sunday, December 7th, 2008 AT 11:33 AM
MURPHY1290
I believe it is the 2.0 gasoline engine with a manual transmission. Thanks
Monday, December 8th, 2008 AT 7:23 AM
JAMES W.
  • 2,394 POSTS
The engine temp sensor is on the driver's side forward (rear) of the engine. If you have, or have access to, a fax #, I can send you a location picture if it will help.
Monday, December 8th, 2008 AT 2:53 PM
MURPHY1290
I do have fax access.
The number is 330-467-1215.
Thanks
Tuesday, December 9th, 2008 AT 8:24 AM
JAMES W.
  • 2,394 POSTS
You should have the fax. Let me know if not.
Wednesday, December 10th, 2008 AT 11:07 AM
BDELOWE
My girlfriend has an automatic 2004 Jetta GL. Can someone please fax me the location of the temp sensor? Is it easy to replace on my own or should I take it to a mechanic? My fax is 323-930-3719. Thanks! Brian
Saturday, January 10th, 2009 AT 4:53 PM
JAMES W.
  • 2,394 POSTS
Fax is on it's way
Saturday, January 10th, 2009 AT 8:45 PM
