HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Volkswagen
Jetta
Fuel System
Fuel Injector
Fuse
1998 Volkswagen Jetta fuel injectors
JONNY69
MEMBER
1998 VOLKSWAGEN JETTA
4 CYL
2WD
MANUAL
120,000 MILES
No power to fuel injector fuse or injectors. Trying to find out where they get there power from
Thursday, July 17th, 2008 AT 5:39 PM
KHLOW2008
MECHANIC
Hi jonny69.
Most injection system provides the power to the injectors via the ignition switch to under dash fuse.
Activation of injectors are through ECM internal grounding.
SPONSORED LINKS
Friday, July 18th, 2008 AT 2:13 AM
Please
login
or
register
to post a reply.
Related Fuel Injector Fuse Content
Injectors Have No Power
Ok I Changed The Injengion, And It Drove Fine I Parked It Went Inside For A Couple Hours And Went To Start It Agian And It Wouldnt Start I...
Asked by
lilchris_king
1997
VOLKSWAGEN JETTA
VIDEO
Fuel Injector Fuse Replacement
Instructional repair video
What Would Cause It To Misfire? I Replaced The...
What Would Cause It To Misfire? I Replaced The Injectors
Asked by
Anonymous
2002
VOLKSWAGEN JETTA
1998 Volkswagen Jetta Fuel Pump
How Do You Take A Fuel Pump Off On This Car? Does It Have Clips Or Something It Seems Stuck.
Asked by
nlhua12
1 ANSWER
1998
VOLKSWAGEN JETTA
Engine Performance Problem 1998 Volkswagen Jetta 4 Cyl Front Wheel Drive Manual 98 Jetta 2.0 L Idles Between 400-600 When Driven...
Asked by
jeremy1876
1998
VOLKSWAGEN JETTA
1999 Volkswagen Jetta Gas Filter
Engine Performance Problem 1999 Volkswagen Jetta 4 Cyl Automatic 113000 Miles Last Week I Took My Car To A Repair Shop To Change The...
Asked by
olga1960
1 ANSWER
1999
VOLKSWAGEN JETTA
VIEW MORE
SPONSORED LINKS
Fuel Injector Replacement
How to Use a Test Light
Misfire
Online car repair manuals
