1996 Volkswagen Golf water enters carburetor
POGIRWIN
  • 1996 VOLKSWAGEN GOLF
Engine Mechanical problem
1996 Volkswagen Golf 4 cyl Front Wheel Drive Manual
what happens if water accidentally enters to carburetor?
how do you it?
Sunday, August 30th, 2009 AT 6:27 AM
  • 31,937 POSTS
Hi there,
This will depend on how much has entered, if only a small amount say a small spoon full, the engine would probably miss a little run rough then clear it self, if it a large amount was to enter say a small cup full this would certainly be enough to do serious damage to the engine, this is call a hydraulic lock as water is not compressible, if a given amount enters the engine it will not compress and if the engine is at speed something will bend or break, I have bent rods from compression locked engines, this is not a good thing.
Mark (mhpautos)
Sunday, August 30th, 2009 AT 8:43 AM
