1999 Volkswagen Beetle Replacing A/C Compressor
RSONTAG
  • 1999 VOLKSWAGEN BEETLE
  • 4 CYL
  • MANUAL
  • 127,000 MILES
My compressor recently stopped working. I Replaced the compressor, dryer and expansion valve as recommended by my local Auto Parts distributor. After removing the parts, I flushed and blew out system. I pulled a 2 hr vaccum after installing the new parts. When I stated charging the system, before getting a full 16oz. Can of R134A in the pressure went up to 80+ lbs. Did I miss something. Is there an orifice on it somewhere that I need to change?
Wednesday, July 16th, 2008 AT 1:54 PM
KHLOW2008
  • 41,814 POSTS
Hi Rsontag,
Did you start the car and turn the AC on while charging?
80 psi is at low side? What is the pressure of high side?
Friday, July 18th, 2008 AT 12:54 AM
BRAUNS BUTCHER BLOCK
  • 7 POSTS
What did you find out about this
Sunday, June 17th, 2012 AT 8:31 PM
VWSCOTT
  • 66 POSTS
Expansion valve at the firewall. If the compressor wore out it's probably full of debris. Also if you charge by small cans the pressure can get high if you turn the can over, you're putting it in as a liquid. You should only shake the can in an upright possition. While the car is running.
Saturday, July 7th, 2012 AT 12:59 AM
RIVERMIKERAT
  • 6,110 POSTS
Rsontag, did you ever figure this out? Blowing the system out with contaminated compressed air can introduce contaminants into the system, but, like vwscott said, you should never turn the small can over.
Sunday, July 29th, 2012 AT 6:08 PM
