HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Saturn
SL2
Engine
Cylinder Head
Valve Cover
Replace/Remove
Need to remove my Valve cover
LESLIE SMILEY
MEMBER
1994 SATURN SL2
6 CYL
MANUAL
170,000 MILES
I just want to take my valve cover off, and was hoping someone knew the size if socket I need. Thank you for the help
Monday, December 5th, 2016 AT 11:29 AM
SATURNTECH9
MECHANIC
Torx T-40 and that holds the valve cover down.
SPONSORED LINKS
Monday, December 5th, 2016 AT 12:21 PM
Please
login
or
register
to post a reply.
Related Cylinder Head Valve Cover Replace/Remove Content
2001 Saturn Sl2 Plastic Valve Cover Replacement.
Hello, Does Anyone Know Where I Can Find The Plastic Valve Cover For This Car? My Motor Mount Bolts Cracked And The Washers Made Holes In...
Asked by
shyannrose
2001
SATURN SL2
99 Saturn Sl2 Hose
I Have A 99 Saturn Sl2. What Is The Name (or Part #) For The Small Hose That Connect Form The Valve Cover To The Air Intake Duct. It Is...
Asked by
yawhatever1
1999
SATURN SL2
1997 Saturn Sl2 Valve Cover
Valve Cover Was Leaking So I Put On A New Casket And It Still Leaks. Torqued Them To. Is It Best To Silicone Them And Or Do They Have A...
Asked by
lalfan
1997
SATURN SL2
I Pulled The Spark Plugs To Replace Them And The Plug...
I Pulled The Spark Plugs To Replace Them And The Plug Nearest The Belt Side Of The Motor Is Bathed In Oil (the Other 3 Plugs And Cylinders...
Asked by
Anonymous
1998
SATURN SL2
Hi, I Am Replacing My Composite Valve Cover On My '97...
Hi, I Am Replacing My Composite Valve Cover On My '97 Saturn Sl2 With An Aluminum Cover From A '94 Sl2. This Is A Legitimate Swap. I Didn't...
Asked by
Jjb4439
1997
SATURN SL2
VIEW MORE
SPONSORED LINKS
Engine Oil Leak
Engine Oil Change and Filter
Serpentine Belt Replacement Mercedes Benz
Online car repair manuals
