HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mazda
Protege
Engine
Symptoms
Stall While Driving
The engine cranks normally then shuts off in 2 to 3 seconds?
A.ROGERS
MEMBER
2003 MAZDA PROTEGE
2.0L
4 CYL
2WD
MANUAL
185,000 MILES
My mechanic is unable to determine the cause.
Thursday, August 10th, 2023 AT 11:40 PM
KEN L
MASTER CERTIFIED MECHANIC
So, the engine cranks and runs or it cranks for 2 seconds and stops cranking over? (starter).
Here is a guide that may help:
Please go over this guide and get back to us.
SPONSORED LINKS
Friday, August 11th, 2023 AT 12:56 PM
Please
login
or
register
to post a reply.
Related Engine Stall While Driving Content
Car Stalls?
Hi, Replaced The Timing Belt On The Car Listed Above, And The Car Now Stalls On Idle And Chokes Off When Hitting Accelerator. Verified All...
Asked by
Bethwah
6 IMAGES
1999
MAZDA PROTEGE
VIDEO
Is it Safe to Drive Check Engine Light?
Instructional repair video
GUIDE
Engine Stalls While Driving
An engine that stalls while driving and then starts back up again, either immediately or after a short time is different from an engine that just wont start or if the...
Car Cuts Off When Turning Right Or Left While Ac...
This Goes With My Other Question Regarding The Ac Causing The Car To Cut Off. The Beginning Of The Month Of June My Step-father Had Changed...
Asked by
roe03
1 ANSWER
MAZDA PROTEGE
Stalling While Driving
1999 Mazda Protege - Occasionally Starts But Then Doesn't Run Long Then Car Does Not Start At All The Car Stalls Out While I'm Driving It...
Asked by
AnglBbyGyrl
1999
MAZDA PROTEGE
1999 Mazda Protege Engine Cuts Out
I Replaced The Timing Belt On A 1999 Mazda Protege 1.6 Engine And After That When Ever I Get On It Heavy And Reach About 4000 Rpm The Engine...
Asked by
david cossey
1999
MAZDA PROTEGE
2000 Mazda Protege Car Dies When Warm
This Car Has Had This Problem Pretty Much Since I Got It ~1yr Ago. It Dies After It Stays Warm For A While, Running The Heater At Full...
Asked by
kr4z33
1 ANSWER
2000
MAZDA PROTEGE
VIEW MORE
SPONSORED LINKS
Code Read Retrieval/Clear - Dodge Stratus
Code Read Retrieval/Clear Mercedes-Benz C230
Topdon OBD2 Scanner Review - This thing rocks
Online car repair manuals
