The engine turns over but does not start?
BOBBYAND
  • 2002 LINCOLN CONTINENTAL
  • 4.6L
  • V8
  • TURBO
  • 4WD
  • MANUAL
  • 150,000 MILES
Doesn't run.
Tuesday, January 2nd, 2024 AT 7:29 PM
  • 108,336 POSTS
In most cases, a crank no-start condition is caused by either a loss of fuel or an ignition spark. If the starter motor is turning the engine, here is what I need you to do:
See if the engine starts with starting fluid. If it does and then stalls, we will know its fuel related. If there is no change, I need you to check for spark to the spark plugs.
Here is a link that explains how to check for spark:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Try this and let me know what you find.
Tuesday, January 2nd, 2024 AT 7:45 PM
