Truck was running smooth than it started cuttering like it was losing gas. I pulled over and it stopped on me.
KEAMICHELLE04
  • 2000 ISUZU NPR
  • V8
  • 170,000 MILES
I'd just filled up on gas and the spark plugs and wires were changed only 2 days before.I checked the fuel filter and that was also okay. The truck was running perfect although it was burning alot of gas. Then out of nowhere it started cuttering as if itwas running out of gas. I pulled over and then it stopped. I can't get it to turn over and the spark plugs seem to not be getting any fire. Please help.
Monday, November 24th, 2014 AT 1:12 AM
HMAC300
  • 48,600 POSTS
Check battery for condition including load test then have charging system tested. Scan for codes and check fuel pressure with a gauge. Auto parts rent it. Most places check battery for free.
Monday, November 24th, 2014 AT 6:47 AM
KEAMICHELLE04
Thank You I will give it a try.
Monday, November 24th, 2014 AT 8:43 AM
