Torque Converter install
ANTHONY BURTON
  • 2001 SUBARU OUTBACK
  • 2.5L
  • 4 CYL
  • 4WD
  • 175,000 MILES
I replaced my torque converter, the original one had a stamp of 90 on it the one that was sent to me had a stamp of 150 on it. Will it work? Everything is about it is the same it fit right in.
Sunday, July 10th, 2022 AT 9:43 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,414 POSTS
Yep, it should work. Can I ask where you got the torque converter? My only concern is that the stall speed might be wrong.
Sunday, July 10th, 2022 AT 4:40 PM
ANTHONY BURTON
I got it from a friend that through a rod, so he pulled the motor.
Monday, July 11th, 2022 AT 9:37 AM
ANTHONY BURTON
When I started it there was a high pitch squeal, so I shut it off and checked to make sure everything was hooked up. After checking I started it again, still had the squeal until I shifted it into reverse and then into drive. Then it had a whistle sound. Any ideas?
Monday, July 11th, 2022 AT 11:26 AM
KEN L
  • 43,414 POSTS
Hmm, the squeal makes me think it is a drive belt, they need to be tight on this car. Can you please shoot a quick video with your phone so we can hear the noise? That would be great. You can upload it here with your response. That way I can tell for sure.
Monday, July 11th, 2022 AT 2:57 PM
