HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Focus
Drivetrain
Transmission
Interchange
Transmission
ALECIA BRANNER
MEMBER
2004 FORD FOCUS
2.0L
4 CYL
2WD
AUTOMATIC
96,000 MILES
I need to know what year a transmission from a 2004- 2007 will these interchange.
Friday, May 19th, 2017 AT 10:39 AM
HMAC300
MECHANIC
If they are both 4F27E and you can hook up the wiring harness to the connectors then yes. The connectors may have changed however.
SPONSORED LINKS
Friday, May 19th, 2017 AT 12:08 PM
Please
login
or
register
to post a reply.
Related Transmission Interchange Content
What Is The Flag Hours To Remove Transmission On 2004...
What Is Flag Hour To Remove
Asked by
wrench2011
1 ANSWER
2004
FORD FOCUS
Shift Solenoid I Think 2000 Ford Focus 3rd Gear
While Driving Goes Into 3rd Gear But Then When My To.S Go Up Or I Go Over Idk 30mph It Disengaged Then When Let Off Gas Or Let Rev Down It...
Asked by
cfocus
5 IMAGES
2000
FORD FOCUS
2001 Ford Focus Manual Transmission Fluid Change
Transmission Problem 2001 Ford Focus Front Wheel Drive Manual 95000 Miles I Need To Change The Trans Fluid On A 2001 Ford Focus. It...
Asked by
pooby1991
1 ANSWER
2001
FORD FOCUS
2006 Ford Focus Change Transmission Fluid
I Removed Pan (has Sealant For Gasket And Replacement Gasket Is Rubber Is That A Problem?) Only Removed 4 Quarts Of Fluid And Has Almost 7...
Asked by
sheldonra
1 ANSWER
2006
FORD FOCUS
2005 Ford Focus Replacing Transmission Solenoids
I Have A 2005 Ford Focus A/t 4-door Zx4 Se, And Its Not A Lawn Ornament. Okay So Truth Be Known I Drive The Mountains In Alaska Often And...
Asked by
focus1
1 ANSWER
2005
FORD FOCUS
VIEW MORE
SPONSORED LINKS
Throw out Bearing Replacement
Transmission Replacement - Automatic RWD
How to Service a Manual Transmission - EASY!
Online car repair manuals
