HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Expedition
Engine
Symptoms
Low Power
While driving the truck it just stopped accelerating?
JESSICA MOFFETT
MEMBER
2002 FORD EXPEDITION
5.4L
V8
4WD
AUTOMATIC
300,000 MILES
I was able to shift into neutral, but truck wouldn't move in any gear.
Friday, August 11th, 2023 AT 12:15 AM
KEN L
MASTER CERTIFIED MECHANIC
The first thing I would do is check the transmission fluid level, this guide can help:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Check the fluid condition as well and service the transmission if the fluid is burnt. This video will show you how:
https://youtu.be/HJdcWI6m3J4
Also, we should run the codes to see if there are any.
Please go over these guides and get back to us.
SPONSORED LINKS
Friday, August 11th, 2023 AT 12:59 PM
Please
login
or
register
to post a reply.
Related Engine Low Power Content
2002 Ford Expedition Engine Runs Very Ruff No Power
Come From A Trip I Came Up A Hill Which Made The Car Down Shift At The Top Of The Hill As It Shifted Back To Drive It Started Missing Really...
Asked by
aaction1
1 ANSWER
2002
FORD EXPEDITION
VIDEO
Fix an Engine with Low Power!
Instructional repair video
GUIDE
Symptoms of Low Engine Power
The power your car's engine is producing is important. When you step on the gas you need your car to accelerate, mainly to keep you out of trouble when getting onto the...
When I Accelerate Hard From A Dead Stop I Get Alot Of Surging And A Lack Of Power, What Could It Be?
Asked by
jimmy352
2002
FORD EXPEDITION
2003 Ford Expedition Has No Power
It Started Off Where It Would Shut Off But Would Start Right Back Up But When You Hit The Gas It Had No Power It Would Not Go. Now After I...
Asked by
pickupgrl1027
1 IMAGE
2003
FORD EXPEDITION
Rough Running In Gear Going Down Road No Acceleration...
Will Not Accelerate In Gear May Be In Limp Mode Got Code Po171 Fuel System Too Lean (cylinder Bank 1). Po442 Evap Control System Small Leak...
Asked by
Robert Yates
2000
FORD EXPEDITION
Car Over Heating And Lack Of Power
Tried To Flush The Radiator And Engine Block. It Seems Plugged At The Block. I Put The Garden Hose In The Block At The Bottom And Nothing...
Asked by
Bill Kupfer
2000
FORD EXPEDITION
VIEW MORE
SPONSORED LINKS
Catalytic Converter Replacement
Online car repair manuals
