Traction control service light service Traction control and Stabil Trak?
HALLIE88
MEMBER
2014 GMC ACADIA
3.6L
2WD
AUTOMATIC
155,000 MILES
Traction control service light service Traction control and Stabil Trak and engine speed reduces.
Saturday, March 4th, 2023 AT 11:18 AM
KEN L
MASTER CERTIFIED MECHANIC
This usually happens when a front or rear bearing hub is going out which houses the ABS wheel speed sensor. The sensor cannot read correctly when the bearing fails due it its misalignment to the reluctor wheel. To find out which one let's use this guide and video to check the codes to see which speed or having the problem:
