E-brake handle pulled out cant get it back in
THE_ROOKIE87
  • TOYOTA PICKUP
I just got an 1987 yota pickup with the 22R in it and the damn thing is not in too good of shape but here my prob. I was trying to get the e-brake set and the damn handle just pulled all of the way out. It didnt even turn like it says on the handle. Well the knob turned but I guess no the rod connected to it. But if u could help me try and get it backin that wpuld be great. Thanx
Sunday, March 5th, 2006 AT 8:02 AM
FISHERMAN
  • 937 POSTS
Check if the handle has a roll pin broken or its just a set-screw loose.
Now use a pair of pliers, pull the handle and with the pliers turn the shaft.
Monday, March 6th, 2006 AT 2:07 PM
THE_ROOKIE87
Thats not the prob. The handle and the shaft are now sitting in the passanger seat with nothing else attached to it. I need to know how to get it back in (attached) so that I can pass an inspection. Would it just be best to go to a junk yard and get a new (used) one?
Monday, March 6th, 2006 AT 11:05 PM
FISHERMAN
  • 937 POSTS
Yes, that`s an easy fix.
You can find it there.
Tuesday, March 7th, 2006 AT 8:47 AM
THE_ROOKIE87
Thank you for the help. I went to the jnuk yard and got the assembly and installed it. Now I just have to go get it inspected. Hope it passes
Tuesday, March 7th, 2006 AT 9:03 AM
