2007 Toyota Pickup shimmy
THENDER
  • 2007 TOYOTA PICKUP
  • V8
  • 10,000 MILES
I have a shimmy in the front end. It is noticable on uneven roads usally around 55 and up. When I drive on smoother roads, I do not feel anything. I took it back to the dealer and they said that it was a balance problem. They rebalanced the front tires, but it still has the same problem. Is this a problem with the 20" wheels on the Tundras? Can it be fixed?
Friday, January 11th, 2008 AT 3:18 PM
FISHERMAN
  • 937 POSTS
Hello !
Rotate the tires and see if that solve the problem.
But, you should ask the dealer to check it good!
Before the warranty expires !
Good Luck!
Friday, January 11th, 2008 AT 4:00 PM
