HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Pickup
General
Fuse Test
2001 Toyota Pickup fuse removal
VAN ROCCO
MEMBER
2001 TOYOTA PICKUP
6 CYL
2WD
AUTOMATIC
65,600 MILES
Battery died. Replaced battery. Wont start. Checked alternator 125 fuse, burned out. Cant get old fuse out. Major headache
Tuesday, July 8th, 2008 AT 11:44 AM
KHLOW2008
MECHANIC
Hi van,
The fuse is attached with screws, remove them before you can take the fuse out.
When 125 A fuse blows out, you should check the alternator for shorting, unless you have installed the battery wrongly to cause it.
SPONSORED LINKS
Tuesday, July 8th, 2008 AT 3:48 PM
Please
login
or
register
to post a reply.
Related Fuse Test Content
1993 Toyota Pickup Blowing Computer Fuses
We Have A '93 Toyota Pu That Was Running Fine. It Quit While Driving Down The Road And Wouldn't Start Again. Got It Home And Found There...
Asked by
AKTracy
1993
TOYOTA PICKUP
Can You Tell Me Which Fuse On My Truck Controls What
I Am Trying To Figure Out What Fuse On My 1985 Toyota Pickup Controls The Cigarette Lighter. The Lighter Is Not Working.
Asked by
jessedr
1 IMAGE
1985
TOYOTA PICKUP
60 Amp Fuse
Why Would The Battery Terminal On The Alternator Ground Out And Keeps Blowing My 60 Amp Fuse? We Have Checked Wire Harness All The Wires For...
Asked by
craftygrannyrose
1987
TOYOTA PICKUP
1992 Toyota Pickup Keeps Blowing Efi Fuse And Fuse...
When First Quit Blew The 15amp Efi Fuse In Fuse Box Under Hood Replaced Fuse Ran For Ashort Time Then Blew Am2 30amp Fuselink Checked All...
Asked by
fats
1 ANSWER
1992
TOYOTA PICKUP
Efi Fuse Got Melted?
What Causes A Computer Box To Have A Slight Burn And Efi Fuse Got Melted Is There A Shortage And Where Can We Find It At?
Asked by
Anonymous
1 ANSWER
4 IMAGES
1990
TOYOTA PICKUP
VIEW MORE
SPONSORED LINKS
Topdon OBD2 Scanner Review - This thing rocks
Radiator Fluid Flush and Fill Ford
Coolant Drain and Refill
Online car repair manuals
