HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Pickup
Drivetrain
Transfer Case
Symptoms
Stuck
SPONSORED LINKS
4 wheel drive stuck in low?
MBUNCH33
MEMBER
1992 TOYOTA PICKUP
6 CYL
4WD
MANUAL
177,000 MILES
I HAVE A 1992 TOYOTA TRUCK THAT IS STUCK IN 4 WHEEL LOW. ANY SUGGESTIONS ON HOW TO GET IT UN-STUCK?
Saturday, August 16th, 2008 AT 11:36 AM
KHLOW2008
MECHANIC
Hi mbunch33,
Most probably the 4 X 4 gear shift bushes are worn and the gear lever is now out of position.
Remove the 4X4 gearshift and manually use a screwdriver to engage to 2 wheel mode. Don't forget to replace the lever bush.
SPONSORED LINKS
Sunday, August 17th, 2008 AT 11:28 AM
MBUNCH33
MEMBER
TRIED TO MANUAL DO IT WITH A SCREWDRIVER BUT IT IS LOCKED IN 4 WHEEL LOW AND WON'T BUDGE.
Sunday, August 17th, 2008 AT 2:40 PM
KHLOW2008
MECHANIC
Hi mbunch33,
You sure you got the correct shift slot?
Any way it requires quite a strong force to get it going and since a screwdriver did not do the job, you need a stronger bar.
Monday, August 18th, 2008 AT 8:00 AM
Please
login
or
register
to post a reply.
Related Transfer Case Stuck Content
1980 Toyota Pickup 4wd Is Stuck In 4x4
I Locked My Front Hubs And Then Put The 4 Wheel Drive Shifter Into 4x4. When I Got Home And Went To Put It Back Into Regular Rear Wheel...
Asked by
1980_toyota_PUP
1 ANSWER
1980
TOYOTA PICKUP
4 Wheel Drive Stopped Working.
I Have A 1993 Toyota Truck 3.0 V6 With 4 Wheel Drive But It Seems To Not Work, Not Sure Why I Pull It In To Go In And It Makes A Clicking...
Asked by
derrick grailich
1 ANSWER
1993
TOYOTA PICKUP
1993 Toyota Pickup Noise In 4wd
I Own A 1993 Toyota Pickup With 116000 On The Drivetrain And Body.I Bought The Truck With A Blown Motor For 300.00. It Has A 22re Crate...
Asked by
93 yota pickup
1 ANSWER
1993
TOYOTA PICKUP
1989 Toyota Pickup 4x4 Won't Engage
When I Shift Into 4 Wheel Drive, The 4x4 Light Comes On But I Can Tell I Am Still In 2 Wheel Drive. Truck Has Manual Hubs And They Are...
Asked by
matsierra
1 ANSWER
1989
TOYOTA PICKUP
2007 Tacoma
My New Truck Has A Problem That Toyota Acknowledges, But Doesn't Know How To Fix It. So They Say It Is Typical But Not Normal. (?) So I...
Asked by
Wondering_spirit
2007
TOYOTA PICKUP
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
Service a Transmission Ford F-150
How to Service a Manual Transmission - EASY!
Online car repair manuals
