2001 Toyota Corolla Engine noise and very very bad performa
PETERYOTA
  • 2001 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • MANUAL
  • 105 MILES
Hello, my engine makes a noise when I accelerate in 3, 4, 5 speed but mostly it's like burning spanking bad and performance is really reduced a lot but mostly its looks shown when going uphill or if theres weight in my car is terrible, I have trouble not stalling when I a start in first speed in a climb and it's consume more. I can smell like gazoline from the foward but theres no check engine. Its started 6 months ago in winter, and when I start the engine on cold the rpm is at 1500 rpm. Spark plug is changed, oil change regulary, tested mass air flow sensor its good, Thank you for your help!
Wednesday, September 29th, 2010 AT 12:55 AM
  • 31,937 POSTS
Hi there,
I would start with all thew tune related items, check for vacuum leaks and do a diagnostic scan to test for any unresolved fault codes.
Mark (mhpautos)
Wednesday, September 29th, 2010 AT 7:33 AM
PETERYOTA
Thank you for your answer I went to garage today. In 2 sec of looking he told me my intake maniafold gasket had to be change and in the hole where you put the oil there is a bump so he tell me my sensor are lost that's why my engine power is so low. But today they had no place but tommorow they will look at my car I keep u uptade!
Wednesday, September 29th, 2010 AT 1:48 PM
  • 31,937 POSTS
Hi there,
I was expecting something like that, let me know how you get on, thank you for using 2carpros, your feedback is always welcome.
Mark (mhpautos)
Wednesday, September 29th, 2010 AT 5:36 PM
PETERYOTA
Ok, he was right there was a leak from the front exhaust pipe gasket and said that his mix all my sensor is clean and my cam sensor then he removed the bump that had purportedly been created through a funnel during the change of oil is then removed a piece of sheet metal inside. But the big problem was really the leak and he told me the lump has to removen cause these important its a VVT-i engine for air helps. Otherwise I have driven the car to get home and its very calm and smooth no noise and easy acceleration all look good. It was a good decision to remove the lump in the engine?
Thursday, September 30th, 2010 AT 3:34 PM
