1999 Toyota Corolla wiper arm contact
THOM HAMILTON
  • 1999 TOYOTA COROLLA
Noises problem
1999 Toyota Corolla 4 cyl Two Wheel Drive Automatic 100 K miles
the left wiper arm hits the right arm when at bottom every cycle, very bad for wife, while driving.
Monday, August 17th, 2009 AT 8:56 AM
DOCFIXIT
  • 18,828 POSTS
Flip up cap on bottom of arm adjust and tighten nut.
Monday, August 17th, 2009 AT 9:03 AM
  • 31,937 POSTS
Hi there,
This is a simple adjustment, undo the nut that holds the wiper blade at the base, lift the arm up and gently wiggle and the arm will come away, it is on a tapered spline, with both arms off, (don't mix them up) turn wiper switch on and off so the pivots self park, re fit the arms so they are aligned correctly, tighten nuts, if in doubt your mechanic can do this very quickly.
Mark (mhpautos)
Monday, August 17th, 2009 AT 9:05 AM
