HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine
Starter
Bolt
SPONSORED LINKS
1991 Toyota Corolla LOCATION OF STARTER BOLTS
JM1326
MEMBER
1991 TOYOTA COROLLA
Engine Mechanical problem
1991 Toyota Corolla 4 cyl Front Wheel Drive 185000 miles
Trying to rmove starter, but unable to locate bolts that I need to unscrew on starter
Wednesday, May 20th, 2009 AT 8:24 PM
MMPRINCE4000
MECHANIC
Two bolts hold starter, one bolt faces the drivers side and one the passengers side.
If you cannot see it from below, remove intake system to throttle body including air box, and you can see it.
SPONSORED LINKS
Thursday, May 21st, 2009 AT 6:04 AM
Please
login
or
register
to post a reply.
Related Starter Bolt Content
2002 Toyota Corolla Starter Bolts
Is T Necessary To Take Off The Exaust System To Replace Starter. I Only See One Screw Bolt But Do Not See The Other One
Asked by
aries73
1 ANSWER
2002
TOYOTA COROLLA
1998 Toyota Corolla Starter
I Am Changing The Starter In A 1998 Toyota Corolla It's Under The Exhaust Manifold. I Can Get Bottom Bolt And Wires Np. What Is The Trick...
Asked by
clueman
1 ANSWER
1998
TOYOTA COROLLA
1991 Toyota Corolla
I Have A Intermiting Problem With My Starter. My Car Is A Toyota Corolla 1991. I Do Delivery With This Car And Let's Say That About Once...
Asked by
wavze
1 ANSWER
1991
TOYOTA COROLLA
1995 Toyota Corolla Replace The Starter Motor
How To Replace The Starter Motor? Thanks.
Asked by
wing
1995
TOYOTA COROLLA
1990 Toyota Corolla Help! Need Help Changing Starter...
Hi, Friends. I Am In Need Of Help In Changing A Starter Motor For My Mother-in-law's 1990 Toyota Corolla. Its My First Time Changing The...
Asked by
JimmyL645i
1990
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Starter Motor Replacement
Starter Replacement
Online car repair manuals
