HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Engine
Cylinder Head
Valve Cover
Gasket
Replace/Remove
1998 Toyota Camry Cost of replacing valve cover gasket
BLUEISONE
MEMBER
1998 TOYOTA CAMRY
4 CYL
FWD
AUTOMATIC
197,000 MILES
Quoted 116.00+tax to replace valve cover gasket. Is this reasonable
Tuesday, January 8th, 2008 AT 2:05 PM
MECHANIC
Hi there,
If using a genuine gasket set and washing the motor etc, that would be about correct, A dealer will charge more than an independent as a rule.
Mark (mhpautos)
SPONSORED LINKS
Wednesday, January 9th, 2008 AT 2:21 AM
Please
login
or
register
to post a reply.
Related Cylinder Head Valve Cover Gasket Replace/Remove Content
1998 Toyota Camry Timing Belt & Valve Cover...
At How Many Miles Should I Get My Timing Belt Replaced? What Would Be A Reasonable Cost? Also The Cost For A Valve Cover Gasket Repair Job...
Asked by
esp22
1998
TOYOTA CAMRY
1997 Toyota Camry Replace Valve Cover Gaskets?
Engine Cooling Problem 1997 Toyota Camry 6 Cyl 145000 Miles Mechanic Quoting Me $365 To Change Both Valve Cover Gaskets, Which Seems...
Asked by
rgbrewer
1997
TOYOTA CAMRY
1994 Camry
This Is A Beater Commuter Car That Has 197,000 Miles On It. I Parked It For A Week To Give It A Full Tune Up And Replace Some Gaskets That...
Asked by
Brittonp83
1 IMAGE
1994
TOYOTA CAMRY
2000 Toyota Camry Oil Usage
My Camry Is Now "using" 1.5 Qts Between Oil Changes, Which I Consider Excessive For A 4 Qt Capacity. I've Always Changed My Oil Every 3000...
Asked by
cantgrowup
2000
TOYOTA CAMRY
2001 Toyota Camry Valve Cover Gasket
I Bought This Car 3 Yrs Ago. Records Showed Valve Cover Replacement At 94,480 Miles. At 98,719 Miles The Gasket Was Again Replaced After A...
Asked by
dreamaudi
1 ANSWER
2001
TOYOTA CAMRY
VIEW MORE
SPONSORED LINKS
Engine Oil Leak
Engine Oil Change and Filter Saturn LS1
Oil Change/Filter Replacement Hyundai Sonata
Online car repair manuals
