Locked steering wheel
TAMNICE
  • 1995 TOYOTA CAMRY
Steering problem
1995 Toyota Camry Two Wheel Drive Automatic 200000 miles
My steering wheel is locked and the key won't turn. What could be the problem?
thank you
tammy
Tuesday, June 22nd, 2010 AT 8:15 AM
  • 31,937 POSTS
It sounds like you need to turn the wheel a little when you are turning the key here is a guide that can help.
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
If that is not it you will need to replace the ignition key tumbler.
Check out the diagrams (Below)
mark (mhpautos)
Tuesday, June 22nd, 2010 AT 9:16 AM
