Tire size
LUKE LUGNORE
  • 2017 CHEVROLET CRUZE
  • 1.8L
  • 4 CYL
  • 220 MILES
My son's car needs winter tires. The tire size on the vehicle is 205 55 16. My question, can I use 205 60 16 for winter tires what would be the deference between 55 and 60?
Wednesday, November 29th, 2017 AT 8:00 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Here is a chart that has the dimensions: https://goo.gl/JuzfHD
Click on specs!
The 205/55R16 overall diameter is 24.8".
The 205/60R16 overall diameter is 25.6".
Wednesday, November 29th, 2017 AT 2:54 PM
JSDORN
  • 12 POSTS
Will the 205 60 16 work on my 2017 Curze?
The 2017 Cruze also can use a 17 rim.
Wednesday, November 29th, 2017 AT 7:17 PM
LUKE LUGNORE
  • 26 POSTS
I am not getting a straight answer. I got dementions of both the 205 55 16 and the 205 60 16 tire. I just want to know if The 205 60 16 tire will fit my 2017 Cruze LT?
Thursday, November 30th, 2017 AT 8:23 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,530 POSTS
Yes it will fit but you will have less freeboard becasue the 205 60 16 tire is a higher profile and will give you a little less room for the tire in the wheelwell. Please post a picture of the currant tire and rim so I can show you what I am talking about please.
Cheers, Ken
Saturday, December 2nd, 2017 AT 4:02 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Yes, the 60 series tire will be 0.8" taller, so not even 1 inch.
The thread widths on both are the same, 6.6"
Saturday, December 2nd, 2017 AT 4:36 PM
JSDORN
  • 12 POSTS
OK thank you.I have another guestion.I want to get rims for snow tires for his cruze. Do
all 16"Chevy rims have the same Bolt pattern
Sunday, December 3rd, 2017 AT 3:39 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I would have to say no, because you didn't say just the 16" rims that fit your vehicle. I am sure there are different bolt patterns but tirerack says yours are 16x7" with a bolt pattern of 5-105, which I believe that is 105 millimeters. Also, there is a Offset of 40mm and a Backspacing of 5.590".
Here is the link to one of those wheels just to show you the specs, https://goo.gl/psMK5k
Sunday, December 3rd, 2017 AT 5:09 PM
