Timing belt broke
JAMIEGILLIAM06
  • 1999 MAZDA B2500
  • MANUAL
  • 175,000 MILES
Timing belt broke, we replaced the thermostat, belt, plugs and wires but the truck loses power in 4th and 5th gear and revs really high when clutch is pushed in, isbrhe timing still off
Wednesday, April 26th, 2023 AT 9:47 PM
  • 108,550 POSTS
Have you checked to make sure there are no engine vacuum leaks? If not, start there.
Here is a link that explains how it's done:
Here is a link you may find helpful as well:
https://www.2carpros.com/articles/engine-idles-too-high
Let me know what you find. Also, let me know if you checked for diagnostic trouble codes. If the check engine light stays on when the engine is running, there will be codes that may help.
joe
Friday, May 5th, 2023 AT 11:05 PM
Related Timing Belt Replace/Remove Content
