Car will not start
RAINY53936
  • 2006 DODGE STRATUS
  • 2.4L
  • 4 CYL
  • FWD
  • 69,000 MILES
My daughter's car would not start so thought it was the starter changed that out, but still will not fire. I was told it was timing belt so I ordered the kit for it, have not got it fixed yet. My question is is that what would make it not fire?
Sunday, January 8th, 2017 AT 7:51 PM
SATURNTECH9
  • 30,869 POSTS
So does it crank and not start? Meaning doe the starter turn the engine over normally and it does not start or does the starter not turn the engine over at all?
Monday, January 9th, 2017 AT 6:51 AM
RAINY53936
The motor turns over but won't start
Thursday, January 12th, 2017 AT 6:54 PM
SATURNTECH9
  • 30,869 POSTS
You could pull the timing belt cover back a little and see if the cams are spining when cranking the engine over. Also have you checked for spark yet?
Thursday, January 12th, 2017 AT 8:12 PM
