Timing belt
MARTINLAKEWYLIE
  • 1999 DODGE STRATUS
  • 2.4L
  • 4 CYL
  • FWD
  • 100,000 MILES
I replaced the timing belt and water pump in our car. I lined everything up properly and now it sounds odd while cranking and will not start. As if there is not as much resistance.
The belt did break while it was running which is why I replaced it.
Any ideas?
Monday, March 20th, 2017 AT 8:44 AM
CARADIODOC
  • 33,748 POSTS
This is an interference engine. If the timing belt broke, valves are going to be bent and will need to be replaced.
Monday, March 20th, 2017 AT 2:42 PM
