Timing
LISA SIKES
  • 2004 CHRYSLER PT CRUISER
  • 2.4L
  • 4 CYL
  • FWD
  • 260,000 MILES
Timing belt broke replaced, started and ran fine. Put the car back together and it will only run if you stay on the gas. Do you have to reset the computer after all this?
Monday, July 25th, 2016 AT 3:39 PM
SATURNTECH9
  • 30,869 POSTS
No you do not have to reset the computer. Is the check engine light coming on?
Monday, July 25th, 2016 AT 7:01 PM
JOHNNY G.JR
  • 320 POSTS
Valve timing could be one tooth off on belt.
Monday, July 25th, 2016 AT 7:16 PM
SATURNTECH9
  • 30,869 POSTS
It could have jumped after the initial timing. Does it have a hydraulic tensor for the timing belt?
Monday, July 25th, 2016 AT 7:18 PM
LISA SIKES
Yes check engine light is on, but it says done. The tensor is doing loaded. I got the timing set right and it started ran great, but I put everything back together it wont run.
Wednesday, July 27th, 2016 AT 9:36 AM
LISA SIKES
I ask this question because a mechanic I know said you have to reset the computer and wants to charge me $35.00 to do this.
Wednesday, July 27th, 2016 AT 9:37 AM
LISA SIKES
The tensor is spring loaded.
Wednesday, July 27th, 2016 AT 9:38 AM
SATURNTECH9
  • 30,869 POSTS
You said the check engine light is on. What are the exact code numbers not code descriptions you have? I have done a lot of timing belts also on that engine I have not run across having to reset the computer after replacing the belt. That is also amazing you did not bend any valves from the belt breaking.
Wednesday, July 27th, 2016 AT 12:30 PM
SATURNTECH9
  • 30,869 POSTS
Something must have happened changed when you finished putting it the rest of the way together.
Wednesday, July 27th, 2016 AT 12:31 PM
