HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Suzuki
Reno
Engine
Camshaft
Camshaft Sensor
2005 Suzuki Reno camshaft position sensor
ZURAB
MEMBER
2005 SUZUKI RENO
4 CYL
FWD
AUTOMATIC
31,000 MILES
What means ciruit bank low signal?
Monday, March 30th, 2009 AT 1:54 PM
BLUELIGHTNIN6
MECHANIC
Indicates an issue with the sensor wiring or the sensor itself. Most common it is the sensor that is failing which will cause this code.
Thanks for using 2CarPros. Com!
SPONSORED LINKS
Monday, March 30th, 2009 AT 1:59 PM
Please
login
or
register
to post a reply.
Related Camshaft Camshaft Sensor Content
Find Camshaft Sensor
Not Getting Fire.
Asked by
Paul Parsons
1 ANSWER
1 IMAGE
2005
SUZUKI RENO
VIDEO
Camshaft Angle Sensor Replacement P0015
Instructional repair video
I Need The Timing Marks.
Hello I Was Replacing The Timing Belt But I Guess I Moved The Pulley So I Need To Know The Marks If I Could Get A Diagram With All The Marks...
Asked by
yannicrisantos
1 ANSWER
2 IMAGES
2007
SUZUKI RENO
SPONSORED LINKS
What to Do When a Check Engine Light?
Code Read Retrieval/Clear Mercedes-Benz C230
Code Read Retrieval/Clear Mercedes Benz
Online car repair manuals
