Stopped at light oil pressure gauge went to 0
TGAY
  • 2002 CHEVROLET BLAZER
  • 156,000 MILES
Stopped at a light and oil pressure gauge went all the way down and engine lights came on, as a accelerated the pressure gauge went back up. Parked the vehicle and water was coming out of the bottom. Checked oil and water were fine. Took it to a shop and was told it was the water pump. Brought it back home and went to start it and it would not turn over, charged the battery and it still will not crank. Any ideas on what else to take a look at? Any fix it advice or things to check out would be greatly appreciated. Thank You
Wednesday, August 21st, 2013 AT 8:45 AM
HMAC300
  • 48,600 POSTS
Oil pressure problem could be electrical so check it manually mine will also do that occasionally as well with the oil and there seems to be nothing wrong with it. Then check fuses and relay underhood for starter. Also check your battery for condition and load test.
Wednesday, August 21st, 2013 AT 9:30 AM
